Results 1 to 5 of 5
Thread: Valve Adj on 2.6
    Jul 2013
    Mt Pleasant, SC
    117
    Default Valve Adj on 2.6
    Trying to help a friend with his valve adjustment on a 2.6. Never worked on a 2.6 before, but I've adjusted valves for the last 35years on various 911's that I have owned, and wondering if I can follow the same principle. Start at #1 TDC ON COMPRESSION, adjust #1, then rotate crank 120 degrees clockwise and continue to adjust in firing (162435) order (COLD)??
    Is there any valve overlap that I need to be concerned about that is unique to this engine?
    tim
    Tim
    63 IIA 88" (Beach with the dogs)
    05 L322 (Daily)
    95 RRC SWB
    05 E320 (Wife)
    86 930 (Rush on boost, 400HP and climbing....)
    A few boring BMW's for the kids (E30, E36, E46, E53)
    Jul 2014
    Santa Cruz CA
    232
    Quote Originally Posted by timc930 View Post
    tim
    Not sure about any overlap issue
    exhaust value 5 and 6 are very hard to get to.
    remove the dipstick for more room..
    Reach out to Bud on Gunsandrover about you overlap issue or RPGreg2600 on are host list. I think Greg has worked of 2.6L engines like Bud
    I have 2.6.l Weslake Head running. One in Blue and the other in Tan
    20/50 oil. Change every 3500 miles or one year.
    What year is his Land Rover?
ID:	12496Click image for larger version.
ID:	12497Click image for larger version.
ID:	12498Click image for larger version.
ID:	12499Click image for larger version.
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
    Jul 2013
    Mt Pleasant, SC
    117
    Quote Originally Posted by clearcut View Post
    thanks for the response....
    Anyone know about using the same procedure that I use on my 930? Is there anything different/unique about the 2.6?
    tim
    Tim
    05 L322 (Daily)
    95 RRC SWB
    05 E320 (Wife)
    Jul 2014
    Santa Cruz CA
    232
    Smile
    tim
    Bud on the gunsandrover list set my values on both
    of my 1967 land rover 109 nada with 2.6 l engine
    greg has a very rare one of these 109.
    not sure if he still
    has the 2.6 l engine
    both could help you with your question
    josh
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
    Jul 2014
    Santa Cruz CA
    232
    Here is the 2.6l engine details
    Hope this tells you more about the value setup
    Also has parts numbers
    Here is the link
    https://drive.google.com/file/d/0B8O...ew?usp=sharing
    josh
    1967 Land Rover 109
    1966 Land Rover 109
    Joshua Tyler
