Yes, it’s normal. Yes, it can be adjusted and should be checked periodically. The green bible does cover it. This is a good starter video to get the concept down. On a rover you can use the hand crank to rotate the pistons/valves to the right spot to check the gap.
If your truck is running smooth/quiet. Let it be. If you’re getting misfire, backfire or other abnormalities, checking the valve gaps is one of several regular tuneup check points.
1968 Series IIa
