Results 1 to 5 of 5
Thread: seeking odometer part
    Jun 2008
    Southern California
    86
    Default seeking odometer part
    I'm seeking a part for an odometer (Jaeger) from my 1970 S2A.
    It is a brown gear wheel, with 44 teeth. Mine looks to be in good shape but it is worn down just enough in places where the teeth no longer catch on the advancing mechanism like they should.
    Here are pictures of the gear, the gear in place, and the face of speedometer/odometer.
    Does anyone have one of these in good shape from an old speedometer or know where I may be able to find one?
    Thanks for any help or sources.
ID:	12598   Click image for larger version.
ID:	12597   Click image for larger version.
    North MS
    980
    Just a quick search, but maybe some helpful things here:
    http://www.britishcarforum.com/bcf/s...dometer-repair
    67 IIA 109" NADA Wagon (sold)
    Jun 2008
    Southern California
    86
    Thanks, I've contacted the vendors mentioned there, and many others, with no luck so far. At this point I'm hoping someone might have a broken speedo that I can salvage the gear from...
    North MS
    980
    May 2011
    Dudley, Mass.
    329
    Quote Originally Posted by andrew View Post
    I'm pretty sure I've got an assembly I could let go to you, say $20 + the ride to you?
