Quick question: I have a (wonderful) Superwinch overdrive unit. The dipstick has a single small notch, nearer the bottom -- what is the proper oil level in relation to this notch? Up to? Above (if so by how much)? Not above?
Here is the only guidance I can find, which says only that the level should be measured with the dipstick screwed in: http://www.landrover.net/overdrive/manual/page8.htm
I've always kept a close eye on the level and have settled on filling it about a half inch above the line, figuring it was the safest strategy (certainly not too low, but also not overly high if the mark is the "high" level).
Thanks.
