Results 1 to 4 of 4
Thread: Oil Filter/Change 2.6 NADA
    Default Oil Filter/Change 2.6 NADA
    Looking at the parts manual there appears to be a small rubber gasket that should go under the oil filter. When I try to find this part nothing comes up. In my truck there was a spring at the bottom of the filter.
    Any ideas? Do I need the spring or the gasket at the bottom?
    Thanks
    Aug 2016
    Plant City, Florida
    58
    Good luck with this. I tried to get an answer a month ago, RN, G&R, UK FB pages, you name it I asked everywhere and nobody had a definitive answer. The parts manual shows nothing except a cork gasket. When I took mine apart the first time it had 2 cork gaskets, a spring and a large washer. Others said they used nothing. I dont think the element has to be forced tight against the top. I don’t think that system forces the oil down the tube and through the element. So I dont think it has to be tight. If so a spring and washer at the bottom would help would make sense but no one came up with that requirement. RN told me there was not a spring or washer. (I think he just looked at the parts book like I did). The new filter I got from RN came with only cork gaskets. So I put mine back together with a larger washer in the bottom, and a cork gasket/spacer and a cork spacer at the top. That is my solution until someone proves there is a better way.
    Nov 2006
    California
    25
    This question put a bug in my ear. Here is some information I pulled together on the topic.
ID:	12726 Click image for larger version.
ID:	12727 Click image for larger version.
ID:	12728 Click image for larger version.
ID:	12729 Click image for larger version.
    -Richard
    1967 NADA 109 IIa SW
    1974 88 III
    Aug 2016
    Plant City, Florida
    58
    Quote Originally Posted by Richard View Post
    -Richard
    Terrific information. Thanks for posting it.
