You don't have to take the entire rod off, but one end must come loose so that you can slide it out of the bulkhead. The hand throttle assembly itself has several hidden bolts. Make sure that you have them all off. There are one or two that bolt up through the lower gauge plate and several at the back, if I remember right.
67 IIA 109" NADA Wagon (sold)
