Rust prevention and Painting new side posts?
I removed my old sideposts and they fell apart into three rusted pieces. I do not want to replace them again. I purchased part RNC831, which says "manufactured with galvannealed steel then dipped in electrostatic E-Coat black primer for superior corrosion resistance. Ready for paint.".
Anyone have suggestions for treating the new posts even further for maximum corrosion resistance...or can I just paint them as the RN description says?
Thanks in advance.....
You should be fine. If you have anyplace that has a seemingly unexposed surface use Waxoyl cavity spray. (Inside door framing and the like.)
'99 Disco II
'76 Series III Hybrid 109
