Results 1 to 4 of 4
Thread: Series III drivetrain slack.
    May 2008
    Eastern, PA
    50
    Default Series III drivetrain slack.
    Driving my 1978 Series III all summer after owning and working in if for years before without driving it, Iím increasingly convinced of some driveline issues. Last Land Rover I drove years ago was a similar age 109 and it was tighter.
    The rear driveshaft will rotate about 120 degrees by hand without the wheels moving; this seems like too much to me and I think accounts for allot of the Ďslopí in the drivetrain?
    Thanks for any insight;
    Tom
    Oct 2011
    Mountains of Western Pennsy.
    539
    Sounds like your worst fear, the ring and pinion are worn badly. And/or the axle splines are badly worn (less likely). I'd be worried if there were only 90 degrees of slack in this.
    '99 Disco II
    '95 R.R.C. Lwb (Gone...)
    '76 Series III Hybrid 109
    '70 Rover 3500S (Gone...)
    Dec 2015
    Northern NSW.Australia
    16
    Ring gear can be adjusted.
    If you have a manual, you can see how to do it.
    On my 77 S3 SWB, I needed also to replace the shims.
    whitehillbilly
ID:	13129   Click image for larger version.
ID:	13130   Click image for larger version.
    Nov 2012
    Helotes, Texas, USA
    72
    If you are in need of a ring and pinion. I have a brand new set I will sell.
    '73 Series III 88 2.25l Petrol, '06 LR3, '08 Range Rover Sport Supercharged
    Helotes, Texas
