Results 1 to 3 of 3
Thread: 1966 Series IIa pentronix ditributor upgrade
    Sep 2019
    Atlanta GA USA
    2
    Default 1966 Series IIa pentronix ditributor upgrade
    Restoring my 66 series IIa 2.24 engine and decided to upgrade the ignition with a Pentronix distributor p/n PRTXD176600. Seems like it's an 1/8" +/- too short. It doesn't engage the drive gear and just spins freely. What am I missing?
    There are two different triangular "Y" shaped aluminum spacers or mounts that fit between the distributor and the engine block. One is thinner than the other. I'm thinking you have the thicker mount. Did you compare your old and new distributors to see if they are the same height?
    Sep 2019
    Atlanta GA USA
    2
    Quote Originally Posted by siiirhd88 View Post
    Hey Bob,
    Thank you for the reply. In an effort to find the different spacers, I called Rovers North. Turns out I'm missing a coupling Model #: PLB328 Funny, I was considering machining a thinner plate or longer drive coupling on the distributor but when the correct part is $10, why bother reinventing the wheel.
    Thanks again for your help.
    BC
Tags for this Thread
