Results 1 to 6 of 6
Thread: When did the dash change in the series II/IIa? Ignition switch problem
    Apr 2020
    Los Angeles
    11
    Default When did the dash change in the series II/IIa? Ignition switch problem
    So mine is registered as 1967, was made in January 1966 according to the certificate from British automobile museum. I have included the dash picture here. Is this the correct dash layout? When did the series change to toggle switches?
    Now the issue: I took out the dash to clean it out , change the glass of speedometer, put everything back but had the unit still dangling down so to say, connected the battery back to test all the lights and after couple of attempts my ignition switch stopped working. Now everything is dead. I checked the wires, power still comes to the unit but nothing happens when I turn the key. Did I short it? Should I start looking for a new ignition switch?
    Apr 2020
    Los Angeles
    11
    Ok. I took the ignition switch apart and found the problem. One of the tabs of the barrel itself is broken, see picture. Anybody can help me source one of these barrels please? I've looked online but can't find it. Its actually not the key barrel itself but the holder that barrel sits in.
ID:	13321   Click image for larger version.
    Oct 2006
    North MS
    980
    Not sure you can buy that piece separately, but here's the switch minus the knob: https://www.roversnorth.com/parts/pl...ries_early_iia
    The dash changed over in 1967 when they went to negative earth and a single dash mounted wiper motor. Yours is correct.
    67 IIA 109" NADA Wagon (sold)
    Apr 2020
    Los Angeles
    11
    Thank you!
    Actually you can be glad your switch failed like this. Mine failed gradually, and would cut out intermittently when driving. It's been long enough ago that I don't remember the trick for replacing the tumbler part. I want to say there's some little release button thingamajig.
    Good luck,
    Myron
    Feb 2007
    Phippsburg, ME
    886
    Quote Originally Posted by jp- View Post
    IIRC that's also why the dash panels went from body color to black: to indicate negative earth.
