Does anyone have any experience with Forbyn Bros. Disk brake conversion, located in california?
Yes.
I have 2 sets installed on both of my 1967 Nada 109
They work great.
Bud (AKA BoulderBtrett) installed both.
We bought there shock plate for the front leaf springs. I run very large shocks. It moved angle back some distance, so the shock would not rub on part of the Forbyn brake Kit
Blue has about 4,000 miles on its set
Tan has about 15 miles total. Tan came home due to Bud house was in the fire zone...
First time Bud drove Tan on the road with new brakes
I run then on the front and rear
josh t
1967 Land Rover 109
1966 Land Rover 109
Joshua Tyler
Thanks, so you did have clearance issues with the front? I have read about Torrell, and Zues adaptation kits, this one was attractive due to the fact that I could still run 15 inch wheels. What other gear, )brake calipers) did you use?
Cheers,
I had no clearance issues, other then the procom shock issue. They are very large..
Are host a has kit for the balance on the parts needed.
I am not sure of the kit part number.
I due run 16 inch tires
josh t
1967 Land Rover 109
1966 Land Rover 109
Joshua Tyler
