Results 1 to 3 of 3
Thread: fuel line
    Aug 2020
    chilliwack BC Canada
    87
    Default fuel line
    My 1960 109 has plastic fuel lines. Not sure if original or not. The compression fitting at the fuel tank switch is leaking. Tried tightening it but still weeps. Any ideas how to fix? The threads on the switch are different from any fitting I have. Are the compression fittings available from somewhere. I has a small section that goes in the plastic hose.
    Sep 2010
    killingworth CT
    836
    What you are looking at is stock, my military, 2 tank with turnover switch has that type of fuel lines, although that end looks different than from what I remember seeing going into the switch. Check with our hosts, to see about that to be sure. I think they may even make those in house, give them a call. Cheers,
    Aug 2020
    87
    Thanks for the reply. Mine may be ex Dutch military.
