Results 1 to 5 of 5
Thread: Backfire and stalling
    Default Backfire and stalling
    I’ve recently starting having a backfire when letting off the gas, mainly in third gear and when I come to a stop it wants to stall. It will idle fine but if you rev the engine and let it return to idle it stalls out. Any ideas where to start? Timing, carb, exhaust?
    Thanks
    1969 series 2a
    2.25 gas
    Electronic ignition
    Sep 2010
    killingworth CT
    836
    Check Idle RPM's, is setting screw set to low?
    Timing, is Ignition timing correct?
    Look at filters, are they clear? Does carb have a filter?
    Plugs, are plug gap correct?
    Could be a myriad of items, choose one and follow through.
    Apr 2009
    Bozeman MT
    705
    Quote Originally Posted by cedryck View Post
    +1 on this post. Think about the engine as a chain. Look at each link in the chain and rule it out.
    Jul 2020
    UK
    302
    Possibly a slight air leak, carb. to manifold or manifold to head.
    Dec 2010
    400
    vacume advance? often though it's vacume leaks.
