Results 1 to 6 of 6
Thread: Clutch pipe routing and bracket location
    Default Clutch pipe routing and bracket location
    Hi I am rebuilding my left hand drive series 3 and canít for the life of me figure out where the bracket goes. Does anyone have photos?
    Thanks
Name:	Clutch bracket.jpg
    On my '73 Ser III 88" there is a solid hydraulic line from the M/C that goes along the back of the firewall over to the other side of the truck, then down to a bracket fixed to the inner fender. From there a flex line goes down to a bracket held to the block by two 5/16" bolts (Ĺ" head). That bracket is bolted to the block right behind the fuel pump sediment bowl. From that bracket it appears that another solid line runs above the bellhousing to the Slave Cyl on the other side. Kind of a convoluted path, but it works. Can barely see the bracket on the photo above
    Thanks so much because mine is a left hand drive it will be different but I am going to go with a bracket on the side of the foot well. Just need to locate a bracket somewhere on the block.
    Quote Originally Posted by Preeve View Post
    Mine is LHD as well, so bracket should be as I show in the earlier post.
    Sep 2010
    killingworth CT
    774
    If I remember correctly, the LHD truck I saw, had plastic clips that helped to hold the clutch pipe to the firewall.
    Wow! That is a convoluted routing! Again thanks so much
