Before installing the drums and shoes I checked to see how the shoes "sat" against the drum. All was good. The fronts have two wheel cylinders, the drums are 11 inch; rears one wheel cylinder with 10 inch drums. No leaks anywhere. I have not taken off the front drums to see if there is a "print". I will do that tomorrow. I still suspect that the bozos at the shop I took it to didn't properly bleed the master cylinder.
Tags for this Thread
- You may not post replies
- You may not edit your posts
Forum Rules
