Results 1 to 6 of 6
Thread: Transmission oil migrating to transfer case
    Default Transmission oil migrating to transfer case
    My S IIA is leaking transmission oil and I noticed that the transfer case was overfull and the transmission was low on oil. Today it had used half a quart in 450 mi. I feel the problem is getting worse. What should I do? And is it possible to use much thicker oil in the summer?
    Jul 2020
    UK
    303
    Quote Originally Posted by Nigel70 View Post
    For a lasting solution, the best way is to replace the oil seal on the main box output shaft to stop it transferring ,. I have never done this with the box in the vehicle, but it may be possible to do it in the vehicle without taking the transfer box off the main box .
    If u call i can walk u thru what's required 360.866.2254
    Thicker oil will not solve your issue and worse, u may ruin your gearbox!!!!
    Quote Originally Posted by charles1943 View Post
    Why not post it here? I've had the same issue for years, might want to fix it if it's not too big a deal. thanks.
    Dec 2010
    400
    I guess my Ramsey winch is about the only thing that doesn't leak!! one day it'll go into the new shop and all that will come out new again, meanwhile it's pretty forgiving, especially the RF hub that leaks it out in about a month.
