Results 1 to 8 of 8
Thread: Series 3 LHD Clutch Hydraulic Hose Pics
    Default Series 3 LHD Clutch Hydraulic Hose Pics
    Hello Forum-
    I'm replacing my sieve of a slave cylinder and while I'm at it, replacing all of the hydraulic lines back to the original routing. Currently, the clutch hydraulic pipe comes off the master, and drops straight down (dangles freely) to connect up with the slave. Proper routing for a Series III LHD is to exit the master into a pipe that runs along the bulkhead, drops down into the flex line which is anchored to the bulkhead, then a third line that exits the flex and mates up to the slave.
    Does anyone have any real pictures to share that shows the correct routing of the pipe that exits the flex line and connects into the slave? The part number is NRC3287. If this routes up over the back of the engine, my concern is that the pipe will be close to the engine and be exposed to engine heat, especially in the summer? Should this be a concern? I have been unable to locate any pics on the internet of what the correct routing of this pipe looks like.
    THANKS!
    -Ben
    Jul 2020
    UK
    303
    Not sure if this helps but this is the shape of the pipe . Click image for larger version.
    Thank you for the picture. That's exactly the pipe I have. Is the proper routing of this pipe up over the backside of the engine flywheel area?
    Dec 2006
    Southern Maine
    279
    Here you go, tear down pics of a NAS 73 ser III 88 , Talbot
ID:	14459Click image for larger version.
ID:	14460Click image for larger version.
ID:	14461Click image for larger version.
    Dec 2010
    404
    Default left/right drive
    Quote Originally Posted by TJR View Post
    these pics are of the clutch on the same side as the exhaust manifold and fuel pump. that's a RH drive right?
    Dec 2006
    Southern Maine
    279
    Not a RHD model ..Pics are from a LHD NAS 88 Ser III 2.25L petrol
    More pics from the same teardown , clutch piping runs across the bulkhead with some brake lines
ID:	14467 Click image for larger version.
ID:	14466 Click image for larger version.
ID:	14465 Click image for larger version.
ID:	14464 Click image for larger version.
    Dec 2006
    Southern Maine
    279
    Ser III clutch slave cyl.Click image for larger version.
ID:	14469Click image for larger version.
ID:	14468Click image for larger version.
  8. #8
    Talbot, thank you very much! These pics are exactly what I needed to see - very helpful!
    Happy New Year!
    Ben
