Results 1 to 4 of 4
Thread: Series Battery Group/Size
    Dec 2006
    Centre PA
    174
    Default Series Battery Group/Size
    Anyone know the correct battery group/size for a series III?
    99 D1
    73 Series III 88"
    95 RRC LWB
    Dec 2006
    Centre PA
    174
    Its group 27F. Its huge!
    99 D1
    73 Series III 88"
    95 RRC LWB
    May 2006
    2,020
    The battery size I use is the type 24, seems to work fine in my Series III Airportable.
    Les Parker
    Rovers North Inc.
    Redding, CT
    1,504
    Quote Originally Posted by Les Parker
    Les,
    Is your battery mounted under the middle seat or in the engine compartment?
    I'm not sure of the size I've got in there but the battery in my SIII airportable has always seemed a bit weak being sat under the middle seat. Doesn't seem to get enough power to the coil while cranking... usually only fires just after I release the starter.
    Suppose it could be a weak ground as well. Just wondering I suppose.
    Cheers,
    Tim
