Valve cover fixings routing advice sought
69 SIIa ....
What is the correct routing for the clips and insulator bushings that hold the fuel line, vac lines, etc that attach to the 3 valve cover studs?
Position 1 (front) there is nothing attached but a clip resides there.
Position 2 (middle) I have the metal vac advance line in the clip.
Position 3 (rear) I have the plastic fuel line in the clip. I have since found that the fuel line should be routed to the front of the valve cover. But I have a Rochester carb installed.
Q#1 Does the high voltage coil wire mount in one of these positions?
Q#2 Does the 12v primary coil lead get mounted in one of these positions?
Q#3 Where is the factory fuel filter located (other than the f/p glass bowl)?
A pic with correct routing would be worth a 1000 words. :-)
Thanks,
Jeff
64 SIIa 109 all stock
69 SIIa 88 all stock
Old tractors
New Harleys
Old trucks
