Results 1 to 5 of 5
Thread: Rich
Hybrid View
    Default Rich
    can anyone help? My 95 RR CLWB 4.2 liter has developed a real loud squeal. Initially I thought it was the ac compressor but, after removing the fan belt all pulleys move (AC, ALT, PWR STEERING and fan blade turn easily) The noise is almost like a whistle and seems to be coming from somewhere below the passenger side exhaust manifold. There is no noise until i give it some gas (with or withhout the fan belt on) at idle nothing????????
    Thanks in advance
    Rich 95 CLWB RR
    Jul 2012
    Tallahassee, Fl
    2
    Rich,
    I'm having the same issue with mine. Did you ever figure out what the problem/solution is?
    May 2006
    2,020
    It could be a bad gasket on either the head to manifold of\r maifold to front pipe.
    Have you tried to re-torque the bolts?
    Les Parker
    Rovers North Inc.
    Oct 2011
    Mountains of Western Pennsy.
    592
    I agree with Les (silly not to, really...), but also it may be a crack in the pipe right below the manifold connection (had one there once...). And sometimes an intake manifold will have a vacuum leak and sound the same (a pressure whistle or vacuum whistle sound alike).
    '95 R.R.C. Lwb
    '75 Series III Hybrid 109
    '70 Rover 3500S
    Jul 2012
    Tallahassee, Fl
    2
    Thanks to all - I now have my project for the weekend!
