Remove the cover inside the wheel well.
You will see a bolt (square headed I believe) and a jam nut coming out the side of the steering box.
Loosen the jam nut and screw in the other checking your backlash while you go.
This pushes the fork on the output shaft over a cone inside the box.
When it's right lock the jam nut back down.
Don't make it to tight!
LH steering boxs are hard to come by.
Steve
