How do I change the temp from C to F? After disconnecting the battery it used celcius as the default.
Maybe I wasn't clear with my question, so I'll try again. How do I change the temperature display from celcius to farenheit? There must be some combination of buttons that toggles the display back and forth between the two scales. Does anyone know how to do that?
With the Climate Control on press and hold the recirclation tab for Three seconds or so... that should work
You will need to push the "recirculation" button AND the "on/off" button at the same time (for about 3 seconds)Originally Posted by 03lrdisco
Peace,
Art
Thanks! That worked.Originally Posted by rover_chump
