Results 1 to 4 of 4
Thread: Transfer Case Seal (Behind E brake)
    Dec 2006
    Centre PA
    174
    Default Transfer Case Seal (Behind E brake)
    So Im in the middle of doing this seal, and rebuilding the emergency brake. Is there supposed to be some sort of felt seal on the output shaft? The RN catalog shows this but mine is definetely missing. Also, what is the torque setting for the big nut? The green bible doesnt mention this. Mine was pretty loose.
    99 D1
    73 Series III 88"
    95 RRC LWB
    May 2006
    2,020
    Default Felt seal
    There should be a felt seal, its there to help ease the flow of 90 Wt. oil creeping down the splines of the output shaft.
    The torque spec is 85 ft lbs.
    Hope this helps.
    Les
    Les Parker
    Rovers North Inc.
    You can use the same felt seal for the hub/axle - plus this one is rubber backed!
    Regards,
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
    Dec 2006
    Centre PA
    174
    Thanks for the info guys. That would explain why I saw more oil dripping from the nut itself....leaking past the splines. And I just happen to have a front axle felt washer in stock!
    99 D1
    73 Series III 88"
    95 RRC LWB
