OK guys,
I got the code thing handled and the ABS.... (just drove it down the road for a bit - as I had just put the new pads and rotors on)
At any rate I had to go through the whole ordeal with the windows not being set, nor the radio working. (I found the code in the owners manual)
Now I have the dilemna of the battery. - I'll check the battery with the voltmeter tomorrow.
One other question unrelated to my first post................ This thing sure makes allot of noise (loke a gear whine sort of noise) when decelerating.... Is this normal? - Truck is basically a highway only useage and only has 62K miles.
- You may not post replies
- You may not edit your posts
Forum Rules
