mine is fitted with a weber 2 barrel 32/36 dgv. when i picked it up the po had bent the linkage and fiddle with the mix to get it to idle and run. there wasn't enough travel to kick open the 2ndary. i rotated the carb 90 degrees and mod'd the lingage so that the idle was an idle and not some weird idle mix combo resulting in about 850 rpms. i found that i had to mod the linkage so that the pedal movememt smoothly rotated the carb's lever through it's full range. bunch of trial and error but i got it. start with connecting it such that there is no force on the carb lever when your pedal's at rest then move the linkage to lever point out to get that full range of movement.
'64 Series IIA 88 Canvas Tilt
'68 Series IIA RHD Ambulance
'76 Spitfire 1500
