Results 1 to 9 of 9
Thread: Mystery Knob?
    Boston
    28
    Default Mystery Knob?
    Any ideas what this knob is for? It doesn't appear to be attached to anything, it's not the cold start. If I pull it out it's attached to a long spiraled rod.
    1970 Series IIA
    Redding, CT
    1,497
    Is it the heat adjuster? Open/closes valve for water to the heater matrix?
    Kingsport
    613
    A "long spiraled rod" is a housing for a push/pull cable. Choke, heater valve control, those are the two that are normally on a Series. Any options on this particular vehicle that aren't "normal"?
    -L
    '72 SIII SW 88"
    '60 SII 88" RHD
    Boston
    28
    Im beginning to believe that there are a number of items that "aren't normal" ie: turn signals on the side panels.
    CT
    290
    Quote Originally Posted by Jared
    1970 Series IIA
    I have a 1971 88" with the same control in the same place. That is the heater control knob. It is supposed to be attached to the coolant valve on top of the head. The valve often leaks, and many owners deleted the valve rather than get a new one, since it is wide open all winter anyway. Pulled all the way out is closed (no heat) and all the way in is 'full blast'; although we all know that is quite optimistic...
    Plum Island
    14
    Looks like the switch for the wipers on mine.
    Tight lines
    Apr 2006
    Vermont
    26
    Hey Jared,
    As mentioned in the previous posts, your mystery knob is connected to the heater control cable. This setup appeared on the North American bound late Series IIA vehicles. Here are a couple parts book diagrams showing the related componants in the heating system.
    Arthur
    Arthur Patsouris
    Sales Manager
    Rovers North Sales Team
    Boston
    28
    Arthur,
    Wow that is really helpful thanks. I was wondering exactly what model I had as I have found some quirky items along the way.
    Which book is that from; it doesnt look like a Haynes Manual?
    jared
    Apr 2006
    Vermont
    26
    Jared,
    These diagrams are from a supplimental parts manual that was published for the North American models. Unfortunately, it's been out of print for years. If you need specific info feel free to pm me or give me a call and I'll be glad to help you out.
    Arthur Patsouris
    Sales Manager
