Results 1 to 7 of 7
Thread: heater switch
    Default heater switch
    the heater switch at blow the air out inside cuts on and off after it warm up.is it the switch are the resister? RRC95 3.9
    thanks
    THEY CALL ME GRUMPY!
    city of maples
    398
    heres my two cents.
    the heater switch could be at fault, ,pull off the face ,undo the screws and check for a loose connection,
    the resistor your talking about is behind the vent(passenger side),most signs of failure is losss of blower speed (only having low speed.)
    i think you probably have a blower motor problem itself. keep us updated marc. http://singingcamel.com
    i'm still working on this switch
    5
    Happened to a friend of mine. It ended up being something with the motor. He took it into the dealer and ended up being quite expensive, so I would try to avoid that.
    ok, looks like it only does this on high speed.(cuts in and out)
    speeds one thru three work ok.
    city of maples
    398
    wondering if you have your problem solved .marc
    got the front one fix.looks like it's the switch.still working on the rear.
