Originally Posted by
TeriAnn
Close ratio? Yep. A T-18 has a 6.32:1 granny first gear, which using 4.7 R&P & C or later suffix transfercase provides a low range first gear ratio of close to 70:1. Stock for a Series IIA is 40.7:1. I find 40.7:1 to be too tall for much of the more technical off road driving I do. But 70:1 is much lower than I need and with V8 torque it is hard to keep the pedal still enough to apply steady power. For the kind of technical driving I do I've tended to prefer a gear around 55:1. I just never use low range first. What good is having a gear you almost never use?
