Originally Posted by
greenmeanie
A couple of things to check.
1. This may be offensive but check the mechanical fan is the correct way round so that it pulls air and doesn't push it.
2. Do you have the cowl in place - it makes a huge difference to the fan efficiency.
3. When she starts getting hot feel the top and bottom radiator hoses. If one is significantly cool you have a blockage.
4. Hold your hand close to the radiator (Don't touch it because that will hurt) and feel for cool spots. If you are fancy and part of the modern world you can get one of those optical thermometer gun things to take readings.
5. How new are the hoses? They can collapse internally partially blocking the coolant flow.
Flushing a radiator can help as part of maintenance but once blocked it very rarely ever shifts the problem. A clogged radiator really needs to be rodded or replaced.
The series cooling system is overbuilt for the original engine and if in good order tends to overcool if anything. A couple of years ago I replaced the water pump, hoses, fan and radiator due to an errant socket left on the crankshaft end nut (Not one of my prouder garage days and a bit of a brown trouser moment with the bang when it came off.). Now I have to put the radiator muff on when it falls below 50° and she only gets up to maybe 3/4 on the gauge during the height of the Phoenix summer.
Cheers
Gregor
