anyone know of a good source of high back seats for an SIIa?
Erik
Erik
tough on your hind end too!
am i really looking at 400$ for a pair? is there a cheaper way? used is fine with me.
Volvo 240 seats. You can get them heated too if you want.
Jeep seats. Common as much used. I bought new Bestop Trailpro's. A simple adapeter consisting of a sheet of metal to span the Land Rover Seat rails plus a couple of lengths of 3/4" square tube and they fit a treat. It even lifts the back of the seat just enough to clear rear flange of the seat box so you get an extra 1 - 1.5" of leg room. They are also quite comfy.
Cheers
Gregor
I put a pair of Corbeau GTS2 in my 110. They are less than Trackers, and more comfortable. I prefer the high side bolsters of the GTS2 but they have many styles.
I've got a set of RRC front seats to put in the lightweight and will be picking up a full set for the 5 door (if I ever get around to that project). Dry fitting shows that it should be easy with the exception of all those silly wires under there.
Any one have a wiring diagram for early 90's Range Rover Classic seats?
Another thing to remember, if you've got under seat fillers, is how you are going to get access to them once the new seats are in. Don't ask me how I know this.
A hole saw should help. It would also be a quite convenient mod to save embarrassment on those long runs with strong coffee and few rest stops.Originally Posted by Tim Smith
That would require a bumper sticker. Which might help ward against tailgaters too!Originally Posted by greenmeanie
Here is something along similar lines for the trail rig that has everything (that you'd want).
Courtesy of http://www.bumperdumper.com
Oh dear, here goes another string down the toilet...
