I'm thinking about new tires - what are some good choices?
There's the Goodyear MT/R
what else? I have 15's also - would it be a good idea to upgrade to 16's?
'67 sort of station wagon (limestone), '65 gray hardtop, '63 blue Station Wagon, '64 limestone station wagon in pieces
I've had great luck with BF Goodrich All-Terrain M&S. They were recommended years ago by Mike Hopwood and Mark Letorney, and I've not been disappointed. The first set went 40,000 miles with a lot of highway driving. They were also great in off road conditions, in winter snow or summer mud.
Then came a set of Coopers that were strong, gave me a little less longevity and a little less off road performance [or else I'm not that good off road anymore ].
So I returned to the same Goodrich tires for my latest set. So far this winter, they've done a great job. The Maine Winter Romp is this weekend, so if - no, when - I get stuck, I can blame the tires
I switched from 15" to 16" wheels many years ago and I am glad for the change. The smaller wheels and tires let you accelerate a little faster but they turn more at speed. If the motor is strong on the car, the 16" wheel serves more like an overdrive. If you switch wheels, you will need to change speedometers, too, or live with an inaccurate reading of the blazing speed of your II-A!
Jeff
Jeff Aronson
Vinalhaven, ME 04863
'66 Series II-A SW 88"
'66 Series II-A HT 88"
'80 Triumph TR-7 Spider
'80 Triumph Spitfire
'66 Corvair Monza Coupe
thanks Jeff! Well I'm actually about 4-5 mph OVER my actual speed at the moment, so my guess is that I already have a 16" speedometer?Originally Posted by Jeff Aronson
Running 255/86R 16's ont the ambulance and 235's on the beater RR, work great in snow ice mud....and you can not beat the price.
1963 Unimog Radio box
1995 LWB RR
Some pretty good info about tires has been posted before. I hope this helps.
http://www.roversnorth.com/forums/se...searchid=26495
I'm running 33X9.50X15 BFG ATs front MTs rear and hate the MTs. They are horrible in packed snow and ice which I drive a lot in. I personally don't see the need for 16 inch rims as long as I can can the 33" BFGs that at narrower.
Jim
It depends entirely how you use your LR. BFG All Terrains are great for most people. I purchase a Set because everyone said they were the best thing since sliced bread, they were great on road, good in snow, and worthless in the mud we have here. The first night I put them on I took them out and promptly got stuck about 50 yards down a logging road I always offroaded on with no problem with my old McCreary Bias Ply tires. Later I got disgusted and gave them to my brother- they worked great for him as long as he stayed out of the mud. He looked pretty stupid at the Guy Fawkes ralley- F+R axles locked and he literally could not get out of the lower pasture. The truck just sat there with all four wheels spinning! Muddy sidehills were another scary proposition. They simply choked up with mud far too easily and became slicks. Tire chains became a necessity.
So IF you do any serious offroading somewhere where there is mud consider a tire with larger voids- a mud type tire with sipes would be a good solution. If you decide to get All Terrains then seriously consider www.tirechains.com
I'm not a huge fan of the Trxus but it is worthy od consideration- it fits somewhere between the all terrains and the more aggressive mud tires.
ymmv
hmm my driving is all over the place.
I do sand on the Cape, mud/wet trails up in New Hampshire, a lot of road in between, and snow in the winter now.
What about those Goodyear MT/R's?
Well do you want a modern tire or an old fashioned one? What is your $ range? Size you are looking for?
Traditional (bias ply):
http://www.stausaonline.com/light-tr...r-traxion.html
Don't get military NDTs or NDCCs
for a modern tire
KevinNY had a Cooper he was fond of and he uses his truck on road and off, maybe he'll tell which model he uses
Cooper Discoverer S/T. They are a very good tire. They fall in the "better than a A/T, almost as good as an M/T" catagory.
99 D1
73 Series III 88"
95 RRC LWB
