Page 64 of 70 FirstFirst ... 14546263646566 ... LastLast
Results 631 to 640 of 693
Thread: 109 NADA Registry
  1. #631
    Nov 2017
    19
    Good morning, I am the new owner of #720. Drivable, but needs some work. Still has the original 6, although the air cleaner unit has been replaced.
  2. #632
    Hi Michel, congratulations! What are your plans for this one?
  3. #633
    Hello Everyone,
    I have a couple of 6 cylinder heads which are stamped 542350, and purportedly Weslake heads, and came with some other items which are clearly NADA 109 related.
    The NADA parts catalogue which Jim Chandler was kind enough to provide me as a pdf, shows the cylinder head assembly as part no. 542349, one digit lower.
    In searching the standard Series 2a parts catalog, the 542350 does not appear at all. The standard 2.6 liter petrol cylinder head in this parts catalog is listed as 564202.
    Any thoughts on the discrepancy or what head(s) I might have?
    Thanks in advance.
    Rod
  4. #634
    Feb 2010
    Bethel, OH
    125
    Hi Rod;
    The Rover 3 Litre Parts Catalogue for the 110 Saloon and Coupe shows 542349 as Cylinder Head Assembly, less Studs Engines with suffix letter "C" and Mk III. 542351 is a Cylinder Head Gasket. 542349 is the Westlake Head.
    Obviously the Part Number was not in play when Parts Catalogue 4825 was printed.
    Jim
    Last edited by patrickfoley1; 12-01-2019 at 11:57 AM. Reason: Spelling and confusing content.
  5. #635
    Thanks for the response Jim. So would you say that 542350 is related to a Rover saloon or or something else? Best, Rod
  6. #636
    Hi Jim, As a follow on, I now have 3 different sources who have visually confirmed that the part number 542350 is a NADA cylinder head, despite the catalog specifying the part number one digit lower at 542349. I came across this same type of one digit discrepancy as it related to the three inch wide drums; have you come across any other type of part number issues like this? And, thanks again for sending me the NADA parts catalog; very helpful. Best regards, Rod
  7. #637
    Nov 2017
    19
    I do not know yet as I have to see what kind of condition is the engine. It's running, plated and insured. I need to do a compression check and determine if the head is still good. The 109 has 102,000 miles, and has done only 3000 miles in the past 20 years. Chassis was repaired in many places. At least the repairs have been well made.
  8. #638
    Sounds like a keeper! Please let us know how you progress. Best regards, Rod
  9. #639
    Nov 2017
    19
    Quote Originally Posted by RoverRod View Post
    Here it is!
ID:	13205Click image for larger version.
Name:	Nada Engine.jpg
  10. #640
    Great paint job!
    Quote Originally Posted by michel View Post
    Here it is!
