Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: LT95 need parts
    Apr 2008
    11
    Default LT95 need parts
    Hi,
    Not really for a 101, but I am rebuilding a 1975 Rangie which has an LT95 and a Fairey overdrive. The problem is I need parts for both..
    Where can I find them in NA or even UK. I have looked up Rimmer Bros in the UK, but I cannot get any info on what is in their repair kits, plus no pics, so hard for me to know what I am actually buying from them.
    TG
    May 2006
    2,009
    Default LT95 PARTS
    Hello,
    What parts are you looking for?
    We can obtain most of the parts for you, why we even have a rebuilt LT95 for a 101 F.C. for $1500.00 !!!
    Les Parker
    Rovers North Inc.
    Apr 2008
    11
    Hi Les,
    Thats nice, is there some diagrams that I can use to identify the parts I am looking for ???
    R.
    Phoenix AZ
    1,358
    Parts for the Fairey LT95 overdrive are no longer made. That is why most of us in 101s end up just swapping in the RR high ration gears. With 900 X 16s it makes for reasonable gearing. WHat parts are you needing - if it is bearings and seals then take the old one out and take it to your local bearing shop and they will see you right.
    THe LT-95 was not sold in the US so most suppliers just don't stock parts although, as our host has just pointed out, they can order them for you. In the UK I would recommend
    http://www.nkrecovery.co.uk/
    He's big in 101 circles. I believe he also does a kit to make a stronger set up for the thrust bearings in the transfer case.
    If not try PA Blanchards as they stock a lot of ex mod stuff.
    Again, what aprts are you looking for? Be aware that the bell housing and input shaft on a 101 are shorter and the transfer case ratios are considerably taller.
    Cheers
    Gregor
    Sterling, VA
    282
    I have a spare gearbox for my Stage One in my garage in the floor. It is in VA (Zip 20165) and I might be pursuaded to sell it. It is complete - but dissassembled. No overdrive.
    Firemanshort
    1980 Stage One
    (Past owner of 1973 Series III - Highlander)
    Default rr gear swap in lt95
    I was thinking about swapping my gears for rr gears in my lt95 box.Is there a place is the usa where you can get these 2 gears?thanks
    Phoenix AZ
    1,358
    The transfer gear swap is not just as simple as dropping in the new gears. You will need shims as well and it is worth inspecting/replacing the bearings while you are in there. Don't forget the o-ring that seals the intermediate shaft. The afore mentioned Mr. Kay will sell you the complete kit to do this.
    I would do some research first, however, as you may find your Range Rover has the high gear ratios in there already. It works well for 101 folk as the stock gearing on the shed is pretty short. I used the highest gear set which is .9962 if that helps.
    You also need a special dummy shaft tool which is easy to make out of 1.5" bar tapped on one end. This is also one of these jobs that is far less frustrating if you have a second set of hands helping.
    Cheers
    Gregor
    I have a 1984 110-not sure what gears are in it and its in the UK until january when I can import it into the states.I bought a overdrive for it-my mechanic over there can install if I want to or do the rr gear swap-just wondering which would be better-gear swap or overdrive-havent had a chance to drive it yet so dont know-but Im assuming if Im gonna drive it on the highway here its gonna need one or the other.
    Phoenix AZ
    1,358
    Overdrive will give you more useable gears and allow you to split shift on hills which is good. The drawback is that the LT-95 units have been out of production for a few decades so none of them are in their first youth. A worn one will howl which is very trying on a long journey. Finding parts other than stock bearings and seals is difficult. If you can, get your UK mechanic to overhaul it before you import.
    The high ratio transfer gear swap will work for your 110. I can't remember it's original ration but the RR is higher. The advantage of this is that parts are readily available and it has no reliaibility issues as you are not adding any more parts than are already there. It is fit and forget. The drawback is that you are still limiting yourself to four gears. It can mean that you have to downshift earlier on hills. If you choose this route have your mechanic do the conversion in the UK - it'll be cheaper and less hassle as the parts are readily available over there.
    Mind you, just to give you an idea, we used to be able to clip the tonne in my brother's stock '83 110 V8. Yes, we were thrashing the bejeesus out of it.
    Cheers
    Gregor
    Southern Wisconsin
    56
    Default I have a factory rebuilt LT95
    That is missing a couple gears I bought it for the lightweight but changed my mind. Just sitting on the shelf in case the 101 blows.
    69 Lightweight
    With Rover V8
    Does a body good
