Page 1 of 2 12 LastLast
Results 1 to 10 of 11
Thread: 2 PROBLEMS
    Dec 2006
    NAPA CALIFORNIA
    18
    Lightbulb 2 PROBLEMS
    I HAVE A 1994 CLASSIC THAT I HAVE BEEN SETTING UP FOR ROCK CRAWLING. THE OTHER DAY I HAD IT ON A 50 DEGREE ANGLE AND THE ENGINE CUT OUT AND WOULD NOT START. I THINK IT COULD BE ASSOCIATED WITH AN OIL SENSOR OR SOMETHING........ANY THOUGHTS. OH YEAH THE CHECK ENGINE LIGHT WILL NOT SHUT OFF NOW.
    SECOND POTENTIAL PROBLEM: DOES ANYONE KNOW IF ITS NORMAL FOR THE MOTOR TO DIE IF THE POSITIVE LEAD ON THE BATTERY IS DISCONNECTED??
    1,199
    Default Not enough info
    Impossible to say from here why the engine died. A sensor wouldn't necessarily shut the engine down, as the ECU has baseline settings that will allow it to operate without input from any sensors at all.
    Maybe you lost fuel pickup, or there is a short somewhere.
    As to the battery, of course if it's disconnected the electrons stop flowing and the engine stops. The same thing happens when you turn the key to the OFF position.
    city of maples
    398
    Default could be
    i would think it could be related to a fuel issue,partially plugged fuel filter ?how much fuel didi you have when off road?
    its not a healthy to disconnect the battery with engine running,could ruin your alt,from what i hear any way ,anyone heard different
    Dec 2006
    NAPA CALIFORNIA
    18
    Default more information
    I had a full tank of fuel at the time of engine death. When on the slope the engine would start but the engine would barely run, as if no fuel was getting to the injectors. It would run for 3-5 seconds then die. I have had a similar problem before with a carberated vehicle where the floats were a problem. Other than the check engine light staying on the vehicle runs fine on flat ground. As soon as we pulled the car to flat ground it ran perfect
    As far as the alternator issue all american vehicles that I have worked on always run with the positive lead diconnected while the engine is running. I'm guessing it's a rover thing that the positive lead needs to be connected at all times??
    another question, do these things have electric fuel pumps or mechanical??
    Niagara Falls, Canada
    44
    Default NO + Connection
    The Rover is not any different than the other American cars you have worked on... You can take the battery out and punt it down the driveway while the vehicle is running, if it stops running, Yes you have problems someplace, the alternator should have plenty of power to keep it running.
    44
    Default Quick question
    This may sound dumb, but is your battery bolted down? Or is it possible that when you put it up on an angle it tills over and shorts out and causes it to stop running? If your Rover is fuel injected, it should have an electronic fuel pump... I'm sure you see what I'm thinking.
    Northern VA
    64
    Default Maybe..
    How about the inertia switch under the front seat. If that pops...you're not going anywhere. I might have thought you flipped over.
    Chris
    Dec 2006
    NAPA CALIFORNIA
    18
    I don't think its the inertia switch since the car ran fine once it was on flat ground. As far as the alternator issue goes, I installed an new 100 amp alternator as well as an Optima red top battery then I drove the vehice for well over a thousand miles waiting for the battery to go down. Everything seems to be running fine other than the fact that the car dies when the positive lead is disconnected.
    city of maples
    398
    Default starving for fuel?
    the simplest thing to do would be to change the fuel filter, if it has'nt happened again under normal conditions ,watch /wait..
    Dec 2006
    NAPA CALIFORNIA
    18
    sounds like a good plan. thanks for the advice
