I did that once in Eastern Montana. I do not recommend it. But it is a good test of how well you lash the stuff you keep inside.Originally Posted by LaneRover
A 2 lane road, mountain on one side, large field on the other. Enough of a hill that full floored I was doing about 50 MPH (SIII 2.25L engine). An 18 wheeler came up from behind doing 15-20 MPH faster than I & passed. Unfortunately there was a second 18 wheeler right behind the first also passing AND an on coming 18 wheeler.
There was enough room for the first 18 wheeler to pass but not the second. The driver of the second 18 wheeler didn't like the idea of a head on at a combines speed of over 120 MPH so decided better me than him and started moving into my lane with me along side. I in turn decided that it would be a good time to do a little off road travel and chose to drive off into the field at 50 MPH rather than be a participant in an accident.
To this day I'm still very grateful that there was no drainage ditch.
That was the last of many close calls caused by faster impatient travelers before I made the decision to swap to a more powerful engine. When I got home I started looking for engines that might work in a Land Rover engine bay.
By the way, when you run your numbers, high range on an Ashcroft transfercase is 0.87:1
NP435 - Ashcroft - 3.54 R&P = 3.08:1 at the axle
With your 32 inch dia tyres that's 2100 RPM @ 65 MPH
Unless you have diesel like torque the gearing may be a little high and you low range would be too high for much off road work.
A close ratio NP435 + high ratio kit + 4.7:1 R&P + 35 inch tyres might work better for you, esp. if you ever plan to go off road.
I'm running a T18 + high ratio kit + 4.7:1 & 33.3" dia tyres (255/85R16)
which gives me 2,700 RPM @ 65 MPH. That's about 200 RPM higher than I would prefer but the 4.1 R&P would put me about 200 RPM lower than my prefered 65 MPH RPM and make second gear a little too tall to start off in (I have a granny first). 35 inch tyres would put me at what I believe to be my optimum 65 MPH cruise RPM, but 33.3 is as tall as I can go and easily enter my land rover in a narrow skirt and flats.
If you have the power to push it I think that tallest you might consider is a NP435 + high ratio + 4.1 R&P. And don't consider this combo with the granny first version
I think the granny gear version is only really useful for either gonzo rock crawling or bragging with mall terrain vehicle owners around a pitcher of beer.
I have gear rations on a web page
http://www.expeditionlandrover.info/gearboxSwap.htm
Play with the numbers.
