Righty's should also have better access to the clutch reservoir if it is a late IIA or SIII truck. No more cutting access panels or removing wings to check fluid levels.
No. Some parts are NLA or No Longer Available. Important parts.Originally Posted by Rosie
Oh it was done about 5 or so years ago back in the UK and featured in one of the landyrags. IIRC it was one of the Bearmach family that did it so they had it a lot easier than the rest of us. It was a bit of deliberate PR to show the extent of their spares holding although it was a SIII.Originally Posted by Eric W S
It would be neither cheap or easy to do. I think that before you could start importing 110s it was an often visited idea to build one as a kit car from parts. At that time it was reckoned to cost about $80K and that was before the dollar tanked.
As stated previously. Much better to start with a project with at least the basics.
Cheers
Gregor
Parts are CHEAP???????????????????????????????????????????Originally Posted by thixon
Land Rover UK built four SIII 88's during a BBC telethon at one point. LROI had a blurb about it a long time ago.Originally Posted by greenmeanie
But you still couln't build a Series One, Two or Two A if you had to buy all the parts from US Vendors. I could see modifying a 90 Bulkhead for a Series 3.
EwS
Relative to some other colector cars I own, or have owned, yeah. Dirt cheap in fact.Originally Posted by Donnie
Travis
'66 IIa 88
x2. Buy A 97 Defender. Parts are gloriously cheap afterward.Originally Posted by thixon
EwS
You've got that right! Try buying a brake master cylinder for a series Rover and then one for a Hummer. I don't have a Hummer, but I imagine that parts AREN'T very cheap.Originally Posted by thixon
