Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Starter trouble
    Default Starter trouble
    hi guys, first time here. I have a 68 series IIA. I recently had the starter motor replaced and just the other day when I went to start the car all I get is a loud click-not a series of clicks but one solid thunk. I am pretty sure it is the solenoid engaging that i can hear through the fire wall. I have charged the battery, replaced the solenoid, made sure that the solenoid is getting a good contact at the ground to the fire wall but nothing. One odd thing-I left the battery charger for a few hours today, just in case and when I came back nothing but I thought I would give the manual crank a try. I cranked a few times still nothing. As I was putting the crank handle away I tried the key again and the starter motor turned over. I couldn't get the car started so it wore the battery down and I have re-charged the battery but now I am back where I started with just the single 'thunk' when I turn the key on.
    Any ideas?
    thanks,
    Greg
    Albuquerque
    1,226
    was i running before the starter replacement?
    '64 Series IIA 88 Canvas Tilt
    '68 Series IIA RHD Ambulance
    '76 Spitfire 1500
    hey scott. yes, the car was running before and after starter replacement. Car ran for a week prior to coming out one morning and nothing but the thunk. One thing I have noticed is that the replacement starter seemed to make noises a little bit like the old starter as it was going bad. The guy who replaced it for me (that is a whole story itself!) seemed to think that it sounded fine. I live in Seattle and we have been experiencing record rain so not sure if that would be a factor. All other power seems to be working, lights, etc.
    thanks,
    g.
    Niagara Falls, Canada
    44
    Default Food for thought
    Do they use spacers on these starters? If so were they all put back in, did the starter loosen off some, could the alignment be out and the bendex just be coming out and wacking the fly wheel? I've had that happen before, it makes a thunk sound and then you get nothing. You might just want to check the bolts and see if they are still tight. I hate starters.
    Rod (not a mechanic, just a guy who needs to make his daily post)
    Thanks Rod. That sounds like it could be right, the system is pretty simple and I believe it is getting power which leads me to believe it is the starter-either a bad one or it wasn't installed correctly.
    Phoenix AZ
    1,358
    Default Have you checked the ground strap...
    between the starter and the chassis?
    Another quick starter test is to take some jump leads and jump straight from the battery to the starter. If it spins you know your problem is the solenoid. If it doesn't do anything then try jumping the neutral as well which would show it is a grounding problem.
    Another thing to check is the leads going from the solenoid to the starter. The insulation can get worn leading to a short and no starting. Also make sure the mounting hardware is tight as a loose starter will not engage properly.
    Finally, was the replacement a new starter? Older starters can develop a dead spot in the commutator for the brushes or just plane worn brushes which will lead to poor starting.
    Cheers
    Gregor
    N. York
    1,635
    when you fastened the cable to the starter did you use a wrench to hold the bolt on the stud near the case?
    there is a nut on the brass stud near the starter- than another one further out on the stud If you don't hold the inner stud immobile while tightening the outer one on the cable the stud can turn and sometimes break a connection inside. It can make for intermittent or complete failure and is a PIA to diagnose.
    It wouldn't hurt to double check all your ground straps, remove and clean them up. "" for the positive leads.
    Land Rover UK Forums
    yorker, you might be on to something.
    I didn't install the starter-when I removed the old starter the retaining ring on the shaft had disintegrated so when I pulled the starter out one of the thrust washers and the main spring fell back into the bell housing-holy ****e!. I don't have the space or the tools to pull the engine so after three days of fishing around with magnets, mirrors and hooks I had it towed to a local guy who works on old rovers and he installed the starter and pulled the motor to fish out the parts that fell back in.
    back to your point about the stud. I was under the car yesterday looking for loose connections and the positive power terminal on the starter seems a little loose, the actual stud. I wiggled the cable to see if I was getting a bad connection and the stud moves a bit but the cable is firmly attached. That sounds like what you are talking about. When you say 'break the connection' I assume that you mean the electrical connection isn't happening not that the stud or something mechanical is broken right? I am guessing what I should do is remove the lead, re-tighten the stud and then hold the retaining nut for the stud while I tighten the cable down. What a PITA, that starter motor is not easy to get to. Okay, this gives me hope.
    N. York
    1,635
    It has been a while since I have done this and it was on rebuilt starters when I did it. I would put the lead on the brass starter stud then tighten it with a socket or somethign similar- not realizing that t would als end up turning the stud once it snugged down. Apparently when the stud started to turn it would break an electrical connection within the starter. It was a dumb error on my part and cost me 2 starters before I realized what was happening to them. I can't remember how I discovered my error. I don't have a spare starter- otherwise I'd post a pic of what I'm talking about.
    are you saying that my doing this (breaking the electric connection) you actually had to replace the starter or you thought your starter was bad and you replaced it before you realised that it was the issue of the connection being bad due to the stud backing out while you were tightening? I am hoping that I can go home, crawl under the truck, do some tightening and be on my way. I do realise the folley of thinking that ANY repair should be so simple but a guy has to dream right?
