The series trucks are fairly easy to crank start- this is of course assuming it is in good tune, and the carburettor is full of fuel...
I hand-cranked mine 1/2 way across North Africa, and that was a freshly re-built engine. A couple turns and it spins fairly easily, if it is in good tune less than three revs will have it running.
My procedure for a cold truck is to pop the hood and pump fuel up to the carb. Make sure the key is on and set the choke. Start spinning! It helps to have another person on the throttle and choke to get the revs up and keep it running, and a hand throttle helps if a helper is not around.
B
Naturally, bad timing, bad fuel, no fuel, low battery, weak spark etc. all make the job harder...
I went through three starters and four solenoids before I had it sorted. I finally ended up with a mean green starter and a Kenworth starter solenoid. NOW, it starts with the key!
1995 110 Regular
