That's a beauty
My name is Rich Lambert and I live in Granite Falls, WA. I picked up my first Land Rover off CL last week. It's a '58 Series II 88". I've always wanted an old Land Rover and this one seems like a good starting point. I say starting point because it sat outside under trees for 10 years, doesn't run, and has some frame rot issues, but I went into this looking for a project.
Congrats! Looks like a typical rover.
Since you wrote that it currently is in a no run condition. I'd recommend starting with the ignition. Make sure the points, condenser, distributor cap, rotor button, spark plugs, spark plug wires, and (very importantly) the low tension lead are all in good condition before doing any other service. the timing should be set or checked too.
Replace all the fluids. Oil and oil filter and radiator coolant. Make sure the engine will turn over by hand.
The ignition is the most important system of the engine to have working soundly it will stop the rig before anything else. Don't do anything to the carb till the ignition is solid. The most overlooked thing is always the low tension lead. That little 2" piece of wire IS the most important wire on the whole truck. Seeing by your pictures that you have the early style distributor I strongly recommend making sure that little wire is in good condition.
If you already know all this then...
HAPPY ROVERING!
Reason: sp
Walker
1968 Series IIA-"Ronnie"
88" SW, 2.25L Petrol, LHD
