Page 43 of 45 FirstFirst ... 334142434445 LastLast
Results 421 to 430 of 442
Thread: Got My Lightweight!! Stay Tuned for Project Updates and Plenty of Questions!
  1. #421
    Feb 2007
    East Granby, CT
    1,884
    The Allmakes slave is aluminum and moves very freely.
    I haven't had a chance to change out the slave yet, but my chirping noise has been absent for a little while. Last thing I did was lube the end of the pushrod that contacts the clutch release fork. That may have helped a little, but I still need to make the slave 'correct'.
  2. #422
    Jun 2009
    Columbus, Ohio, USA
    740
    Drove it down to Lake Cumberland, KY for a boat trip. I had so many neck breakers staring at it on the way down made me feel special. Only when I stopped at a red light did I realize they were staring at the underside where hot oil was pouring onto the exhaust just behind the manifold. Flaming rover anyone?
    Lessons learned:
    - VERY TIGHT is the level of wrenching required to safely install a oil PSI gauge.
    - NEVER install an exhaust system under the places oil is most likely rain from
  3. #423
    N. York
    1,635
    nono
    Quote Originally Posted by amcordo View Post
    Funny how Land Rover never got that....
    Land Rover UK Forums
  4. #424
    Quote Originally Posted by yorker View Post
    'Cause LR were 007 DB5 fans....
    Tom P.
    1965 exMoD 109
    1995 RRC LWB w/EAS
  5. #425
    Apr 2008
    The Granite State (NH)
    3,435
    That doesn't leave many places to put an exhaust system in a Rover. Are you suggesting an exhaust system that goes through the bonnet and over the truck?
    --Mark
  6. #426
    Albuquerque
    1,226
    ...suggesting an exhaust system that goes through the bonnet and over the truck?
    this would only work 'til ya roll it
    '64 Series IIA 88 Canvas Tilt
    '68 Series IIA RHD Ambulance
    '76 Spitfire 1500
  7. #427
    Feb 2007
    East Granby, CT
    1,884
    Anyone have any experience with the military hazard/signal light relay as used on the Lightweight?
    Every once in a while, my signals don't work - no clicking from the relay for either RH or LH. If I turn on the hazards, it usually starts working. Alternately, as soon as I touch the plug on the relay, the signal lights start to work. I'll double-check all my connections. I just hate to relace that relay if I don't have to - it's very expensive.
  8. #428
    Albuquerque
    1,226
    it the relay anchored? is the anchor point also the ground? is the ground good?
    '76 Spitfire 1500
  9. #429
    Feb 2007
    East Granby, CT
    1,884
    ^Yes, yes, and yes (should be). The relay is mounted to the bulkhead. I was very careful to clean the paint from around one of the mounting bolts - the one used as a mounting point for the ground wire.
    Thinking about it, the bulkhead checks out as grounded when using a multimeter (continuity to the negative side of the battery). But, I guess I could always be absolutely sure about the ground and run a dedicated ground wire from the negative battery side to the relay ground wire. Would only take a few minutes and is probably worthwhile anyway since the bulkhead is used as a ground for the instruments.
  10. #430
    May 2006
    2,020
    Default Relay number
    What's the Lucas number on your relay, I may have one avail...
