I did some searching, but didn't find what I was looking for. On my old 63, the wheel bearings were oil lubricated and the hubs had small oil fill ports to allow for an initial charge of oil upon re-assembly. My 73 SIII doesn't have these ports. All I have right now is the SII/IIA green manual, but it doesn't mention anything about using grease on the wheel bearings.
So, should the wheel bearings on the SIII be greased? If so, won't the oil from the rear differential or swivel pin housings eventually contaminate the grease? Just wondering what everyone else is doing.
Also, can someone point me in the direction of info on greasing the swivel pin housings versus using oil?
Thanks,
Jeff
