Results 11 to 20 of 22
Thread: MTF
  1. #11
    Redline MTL is said to be the best thing you can do for your R380.
  2. #12
    May 2006
    2,020
    Hmm,
    Is there any data to back that? I'd be interested to see some testimonials.
    Les Parker
    Rovers North Inc.
  3. #13
    Sep 2007
    Mystic CT,
    583
    Quote Originally Posted by Terrys
    Land Rover always specified using ATF in the LT77 and R380 5 speed manual gearboxes,.
    Is the Lt77 the transmission I have in my 72 NAS series III 88? Its a four speed, should i be putting ATF in there vs. 90wt?
  4. #14
    May 2007
    Bloomfield, CT
    1,382
    Quote Originally Posted by rwollschlager
    An LT77 is a 5 speed with internal oil pump, hence the original directive for ATF.
    You want a suitable gear oil with a viscosity in the 85 or up range, but deffinately not ATF. (Use 85W-130 for the winter)
  5. #15
    Sep 2007
    Mystic CT,
    583
    thanks, im going to be changing all the fluids one of these weekends just makin sure im using the right stuff
  6. #16
    May 2006
    2,020
    LT77 is a 5 speed tranny, if it is the later LT77S, with synchro 5th gear, I would use the MTF.
    LT76 is the Series 4 Speed transmission.
    LT = Leyland Transmissions
    76,77,85,95 is the diameter of the mainshaft in millimeters.
    Les Parker
    Rovers North Inc.
  7. #17
    Land between the Rivers
    22
    Quote Originally Posted by Les Parker
    Really? I thought it was the dimension between the centerline of the mainshaft and layshaft......
    Don't worry, you're biodegradable.
  8. #18
    Jan 2008
    Concord, Va
    111
    can't speak to the Amsoil product but I use Redline MTL in 95's, 77's and 380's.
    In my personal truck (lt77s) I noticed a pronounced difference when
    I put the Redline in. I have been buying it from some fellow on ebay in Pa for a bit over $8 a qt.
  9. #19
    Feb 2009
    McCall, Idaho
    6
    My 110 was dealer serviced in 2001, just prior to my getting it, and the service report indicates 8 quarts Dexron ATF. I guess Miami didn't get that memo.
    8 Quarts? Hopefully you got about 4.5 quarts in a 'to-go' box. If I'm not mistaken, the R-380 takes about 2.7 litres (4.7 pints) and the LT-77 takes even less at 2.2 litres (3.9 pints).
    I just ordered a gallon of Redline MTF in hopes of eliminating the dreaded 2nd-gear grind. I have tried 80W-90 and then ATF. Both with the same result. I'll try to follow up with the results.
    When I took delivery of my D-90 the gearbox was empty.
  10. #20
    Mar 2007
    Killingworth CT
    351
    Les thanks for that info about the tranny classifications, learn something new everyday.
