Page 3 of 3 FirstFirst 123
Results 21 to 22 of 22
Thread: MTF
  1. #21
    May 2007
    Bloomfield, CT
    1,382
    Quote Originally Posted by geatlander
    8 Quarts? Hopefully you got about 4.5 quarts in a 'to-go' box. If I'm not mistaken, the R-380 takes about 2.7 litres (4.7 pints) and the LT-77 takes even less at 2.2 litres (3.9 pints).
    I just ordered a gallon of Redline MTF in hopes of eliminating the dreaded 2nd-gear grind. I have tried 80W-90 and then ATF. Both with the same result. I'll try to follow up with the results.
    When I took delivery of my D-90 the gearbox was empty.
    As I said, above, that was before I acquired the truck. In any case the 110 has a high capacity transmission oil cooler, which the 90 does not have. That, alone takes an additional 2.5 quarts.
    I'm not surprised you have difficulty using 90 weight, since the internal oil pump in an R-380 can't even pump it.
  2. #22
    Quote Originally Posted by Les Parker
    Hmm,
    Is there any data to back that? I'd be interested to see some testimonials.
    http://www.d-90.com/forum/showthread...ht=redline+mtl
