Results 1 to 4 of 4
Thread: Recommendations on Speedo rebuild
    Nov 2007
    NY
    384
    Default Recommendations on Speedo rebuild
    The digital numbers on the odo of my 97 D90 are barely visible anymore. Any recommendations on a place that repairs this issue?
    1965 109 2door hardtop (restored years ago)
    1971 88 (restored and as new)
    1967 88 (the next project)
    Jan 2008
    Concord, Va
    111
    I think ECR has figured out a fix for these.
    http://www.eastcoastrover.com/speedo.html
    Nov 2007
    NY
    384
    Anyone else fix them?
    Feb 2009
    McCall, Idaho
    6
    Quote Originally Posted by Bertha
    You may be able to easily repair this yourself. In most cases, it is the ribbon cable to the display that goes bad, not the display itself.
    Remove the speedometer. Remove the case from the speedo. Remove the ribbon cable (there should be small clips that retain it to the 'plug' on the circuitboard). Count the number of conductors (maybe need a magnifing glass). Order a replacement on ebay or from an electronics parts house.
    Ribbon cables are commonly used on many electronic devices, especially notebook computers. If you are lucky, you should be able to track one down with a little research.
    Might be worth a try, anyway.
