Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Help a RR noob. please
  1. #11
    Jan 2009
    6
    ok so pulling right where the arrrow is with vise grips should do it? it seems very hard to pull
  2. #12
    Mar 2007
    Killingworth CT
    351
    if you haven't pulled the lever before then you might want to spray some PB blaster of liquid wrench on the broken end into the housing and on the latch end through the grill just to try and loosen things up.
  3. #13
    Nov 2006
    136
    there should be a cable inside the housing that the green arrow points to. you want to pull the cable not the housing.
