What a bear this is going to be, unless one of you saints can pass along a double-secret methond for loosining, removing and then replacing the filler hose joining the filler tube assembly to the fuel tank. Mine has (apparently) a split in the rubber underneath the cloth covering and leaks when filling. I have ordered the new hose piece but can't get the old one out.
The main dilema here is how to loosen the upper clamp on the hose section as it is conveniently (sarc.) located inside the wall / bulkhead separating the front seats and the rear cargo area. No access from the backside or front that I can see.... I can only think to remove the entire fuel tube assembly but that is nicely rivited to the body.
Help
