1983 Land Rover Defender 110 CSW
For Sale: 1983 Land Rover Defender 110 CSW. Original 2.25L Diesel with 5 spd LT77 and 98k miles, RHD, blue and white, the original chassis has had the rear crossmember replaced, and the front outriggers have been patched. The bulkhead is nearly perfect except for the right side foot-well which has been patched (professionally welded). Any visible rust has been removed, rewelded, and treated with nutri-rust. It has the original paint, very straight body panels and very little corrosion. It has seat rail extensions for the driver’s seat (adds 6” of legroom). Also new: heavy duty springs and shocks, filters, and seat covers. A lot of screws, nuts and bolts were replaced with stainless steel ones. This is a nice example of an original spec 110, it would be good for a collector, or a good project vehicle for a 200tdi conversion. It is currently located in La Verkin, Ut (2 hrs from Vegas). It is a fully legal import being over 25years old, and is approved by the EPA and the DOT. It is currently registered and titled in Utah. Asking $14,000.00 obo. Additional photos can be seen at www.blueradventures.com rgbfsa@hotmail.com
Reason: new location
Land rover
Could I call you or you call me (905)893-1086
Doug
