Results 1 to 3 of 3
Thread: Help with WATER INLET-300 TDI
    Default Help with WATER INLET-300 TDI
    I have a small leak at the top of the WATER INLET can this be JB welded or do I have to pull everthing off and replace gasket
    thanks stevo
    br549
    Check the silly plastic plug on top before you replace anything mine seeped for a while and then let loose all together. Carl
