Results 1 to 4 of 4
Thread: Short Block Question
    Default Short Block Question
    My 00 Disco II has a cracked block, my 96 Disco I a smashed front end, I'm told I can't put the 96 engine and transmission in the Disco II (or can I ?). Can I use the top end of the Disco II (heads, intake, ignition, ect.) on the short block from the 96 Disco? Are the blocks different?
    Feb 2009
    Cincinnati
    130
    Unless I am mistaken (this does happen to me) it is the same 4.0 engine block.. the big difference is the switch from GEMS to Bosch.
    Joey
    97 Disco
    10 MCCSm
    Custom Rover Accessories
    Home of the D2 horn buttons
    May 2006
    2,020
    Yes, the CPS has a different mount, along with all sorts of electro gizmo's that are not compatible.
    Les Parker
    Rovers North Inc.
    May 2009
    chicago area
    11
    has anyone ever had the cylinders re-sleeved? my 2003 discovery has a cracked number four cylinder wall.
