Originally Posted by
57loboy
When you have issues with the mirrors/seats on the 95s, it is usually related to the seat ECU (located under the drivers seat). There's a Varta brand battery in there that goes bad from age and wierd things can start happening. Try taking out the ECU to see if the circuit board inside is corroded. If it is, you need a new ECU. If it is clean, it's usually the battery which can be had for $10 or so on ebay and a little time/confidence with a soldering iron. Cheap way to fix it as the good used ones go for $150+ and the dealers want mega $$$ for one.
I had the same issue and agree with 57loboy. I live in Thousand Oaks, CA and took my module into a company called BatteriesPlus (they sell all kinds of batteries). Anyway they had the 3 Varta batterys and resolderd 3 new ones back in. Bingo everything works for $20.
Paul
1995 LWB Range Rover Classic
2001 P38A Range Rover
